simhydraulics/volumetric efficiency
Hi
First time using this software. If one creates a simple circuit with a pump driving a motor. Then altering the pump volumetric efficiency should effect the pump output flow rate. Not in this software, at least it does not effect the steady state volume flow rate.
Am I missing something?
Thanks in advance
allan
