Pipeline material selection
Dear,
Can someone helps me to find/tell me where is the right procedure for pipeline material selection in the ASME B31.3 Process Piping.
Application : Compressed 40 bar air / 2 " conduit.
Regards.
Regards.
RE: Pipeline material selection
http://igs.nigc.ir/STANDS/IPS/E-PI-221.PDF
http://tenders.hpcl.co.in/tenders/tender_prog/tend...
http://www.scribd.com/doc/180103930/ARAMCO-SAES-L-...
Dejan IVANOVIC
Process Engineer, MSChE
There is a big difference in the codes between the two....
Compressed air is as benign a fluid as you can get. Use A105.
Instrument Air: Carbon steel; carbon steel + hot dip galvanising; 316(L) stainless steel
Plant Air: Carbon steel; 316(L) stainless steel
Considerations in making a choice could be such things as likelihood of water condensation, consumer requirements for cleanliness
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
this thread can provide an amplification about this matter.
thread378-176105: Compressed Air Piping-Material?.
El que no puede andar, se sienta.
El que no puede sentarse, ni andar, ni enseñar, ni hacer, debe administrar.
¡Buena esa, racookpe1978 ! Es la cruda y triste realidad.
Where is you installation site is located? If you can't give exact location, tell us nearest town location.
Is it indoor or outdoor? Above or below ground?
What is for this 40 barg = 580 psig compressed air is used? Is there any air conditioning unit installed after an air compressor?
Curtis
Code does not suggest Material selection. It provides the restrictions for a specific material.
You have to use your own judgement according to the location, design and operating conditions, vendor experiences, client experiences and specifications, fluid list and the list goes on and on.
Please rule out your suggestions for material selection one by one before arriving at conclusion.
Also keep in mind the cost and corrosion factor.
The posts related to this query by other respected and experienced members are beneficial and helpful. Please use their experiences
PME
Hard Work with Smartness is the key to success
