Wrinkling vs Inter-rivet buckling
Can somebody shed some light on the difference between Wrinkling vs Inter-rivet buckling. Is one more critical than the other on a riveted skin panel?
Wrinkling vs Inter-rivet bucklingWrinkling vs Inter-rivet buckling(OP)
Red Flag SubmittedThank you for helping keep Eng-Tips Forums free from inappropriate posts. Reply To This ThreadPosting in the Eng-Tips forums is a member-only feature.Click Here to join Eng-Tips and talk with other members! |
ResourcesThe world has changed considerably since the 1980s, when CAD first started displacing drafting tables. Download Now
Prototyping has always been a critical part of product development. Download Now
As the cloud is increasingly adopted for product development, questions remain as to just how cloud software tools compare to on-premise solutions. Download Now
Engineering-centric businesses face a number of challenges today, but unmanageable design and change processes don’t need to be counted among them. Download Now
RE: Wrinkling vs Inter-rivet buckling
Inter-rivet buckling, on the other hand, involves an area of material that has deflected significantly between the fasteners, regardless of the overall shape or size of the panel. IR buckling is usually associated with compression in the joint with the fasteners.
Do you have a copy of Bruhn? There are several discussions, with diagrams & photos, in C7, C8, C11 and probably elsewhere.
STF
The classic reference for wrinkling is NACA-TN-1255, figure 1 is a good illustration of the wrinkling/inter-rivet buckling relationship (pdf): http://naca.central.cranfield.ac.uk/reports/1955/n...
The handbook of structural stability is a good reference too (pdf): http://shellbuckling.com/papers/classicNASAReports...
Both of those references are basically summarized in Bruhn.
- At IRB, the skin between fasteners buckle locally. This do no deform the attached flange.
- At wrinkling, the skin has to deform in a way that it also deforms the attach stiffener. Thus wrinkling failure is a combination of skin and flange failure and could occur due to high shear stress as well.
At both these instances, these loads will induce tension loads on attached fasteners and fasteners need to be checked in tension
Thank you for your replies.
Your conclusions are concise and to the point,and I can see no error it their logic,good rules to go by.those old NACA/NASA documents are a real treasure trove if anybody has the time and patient to go thru them,I'm wondering if they are printed and published somewhere,anybody know ?
Just to complicate the picture.
RE: ANSI H35.2 Dimensional Tolerances for Aluminum Mill Products
Perfect flatness of raw material [sheet, plate, etc] is a fairytale. Per H35.2, aluminum sheet is 'allowed' an as-manufactured out-of-flatness tolerance that is substantial for large flat skins, webs, etc... but perfectly adequate for small flat, flat-formed [bent or hydroformed] parts such as frames, ribs, intercostals, formed-spar channels, etc. Just look at the average wide/long sheet of clad aluminum from a shallow angle, and this phenomena is easy to observe!
Just about ever GA aircraft out there has waviness induced by the natural-out-of-flat condition of the raw sheet aluminum stock. Perhaps these tolerances can be reduced a bit for 'premium sheet-stock' with extra flatness requirements imposed [$$]; however this is not the rule from most raw sheet/plate aluminum stock. Same goes for any 'hard' alloy made from titanium, CRES, Inconel, etc.
When assembled to rigid structure, there is a tendency for large skins/webs to form shallow waves or pillows between rigid members, such as stiffeners, frames, fittings, etc. Often adjacent open bays may have opposite tendencies: one bay pillowed-out, adjacent bay pillowed in... and natural wrinkles and large pillows may actually pass-thru these rigid edge attachments. Most GA Acft, when taxied at low speed and low power [reduced noise levels] can produce some awful popping/snapping sounds... clearly indicating that the skin/web is in a state of dynamic flex in these 'oil-canned bays'.
NOTE. The technical term for 'oil-canning' is [gasp!!!] 'snap-thru elastic buckling', which describes the nature of the beast: the member snaps from one-state [EX bowed-out] to the opposite-state [bowed-in] elastically, and almost instantly, with very little force [transverse to the sheet plane]. The problem with oil-canning is [generally speaking], fatigue cracking at periphery fastener holes due to the large number of oil canning cycles per flight [which are not usually heard]. Even though flight loading can mitigate the problem for awhile, still experiences various stress states in non-static-flight conditions; and eventually the structure still has-to return to it's normal static state when tied-up on the flight line. NOTE: the poor riveting practices noted in a previous post [excessive localized swelling due to rivet installation pressure] is a great aggravating factor for this phenomena!
NOTE.
I have encountered a phenomena where localized overstress due to poor fastener-fit [and also poor riveting practices - another story], mechanical or flight loads has induce permanent distortions resembling natural oil-canned sheet, that make it 'easier' to 'oil-can buckle' with less/less energy...' at lower and lower outside loading. In worse case instances, fasteners in holes can also loosen/smoke/crack... and worst possible case is where flutter [natural vibration] frequencies can change... usually for the worst [IE flutter at progressively lower airspeeds, etc].
NOTE. The aircraft I work on was designed with secondary wing rib webs allowed to diagonal-tension-wrinkle at/above limit load: rivet-hole cracking is a major problem. I suspect that, even though the thin web sheet used was perfectly adequate by analysis/test, it had enough inherent natural flatness tolerance issues to be a 'set-up' for oil-canning 'as-riveted into position'; hence premature failure.
Regards, Wil Taylor
o Trust - But Verify!
o We believe to be true what we prefer to be true.
o For those who believe, no proof is required; for those who cannot believe, no proof is possible.
o Unfortunately, in science what You 'believe' is irrelevant. ["Orion"]
o Learn the rules like a pro, so you can break them like an artist. [Picasso]
This illustration from Niu shows the difference between Inter-rivet Buckling vs Skin Wrinkling.
This may be slightly OT, but what is the physical significance of Farrar's Efficiency Factor?
