Copying multiple part bodies and pasting into a single part.
I have hundreds of "standard parts" instantiated in an assembly.
Now I want to copy all of the part bodies in each of the hundreds of parts and paste them all into a single detail part that will act as a collector for the parts.
I have not been able to find a way to select multiple part bodies from different parts and copy them all and then paste them into a detail. I have only been able to do this manually by expanding the tree, selecting a single part body and then copying it into my detail. Then I have to keep doing this process for each and every part in my assembly, which is hundreds of parts.
Does anyone have a method to accomplish what I'm asking? A helpful hint? A macro?
RE: Copying multiple part bodies and pasting into a single part.
You could also use Add to Associated Part in the Assembly Design workbench
Drew Mumaw
www.textsketcher.com
www.drewmumaw.com
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
Only two ways.
1.Use CATproduct to part in the Assembly design workbench.
2.Macro.
