Steps to Model This Part?
RE: Steps to Model This Part?
First...what version of NX are you using? (suspecting it is NX10)
but this would be a nice candidate for the sweep along guide with solid body....
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
Hi Ronald,
Yes using NX10.
The helix is variable but the radius in the root changes as well so I did not think I could sweep along a guide?
Thank you!
John
Should be possible with variational sweep.
Quote (Siemens)
Use the Variational Sweep command to create a body by sweeping a cross section along a path where the shape of the section varies along the path.
You can do the following:
•Sweep faces that are coincident, tangent, or normal to other curves and faces.
•Add secondary sections to vary dimensions at specific locations.
•Extend the body beyond the length of the path or limit it.
NX9 / TC10.1.2
HP Zbook15
Oh...one additional comment...The Sweep body is not available in NX10....
NX9 / TC10.1.2
HP Zbook15
