Regarding Drafting
Regarding Drafting
Regarding Drafting
Is there any option like half dimension(as in catia)or symmetry dimension in NX8.5.
I need to give that dimension in drafting.. sad
RE: Regarding Drafting
Its a revolved section.
Two way's
1 - You can switch off (dimension settings) the arrow and dimension line from the side you don't want to see (horizontal and vertical dimensions)
2 - With the cylindrical dimensions when you pick the centerline first and then the cylindrical edge it will show the real dimension (it actually doubles the radius)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
But 3d centerline is not displaying for revolved section:(
So add it in there. It's a Utility Symbol. If you want them to display automatically when views are placed, you'll have to edit your Drafting Preferences and/or Customer Defaults.
Tim Flater
NX Designer
NX 9.0.3.4 Win7 Pro x64 SP1
Intel Xeon 2.53 GHz 6GB RAM
NVIDIA Quadro 4000 2GB
Thank you Ronald n Tim:)
