Soil-Foundation Friction Angle (Friction Angle for Foundation Surface)
I am trying to get some clarification regarding the Soil-Friction Angle (Friction Angle for Foundation Surface). Have seen different calculations from the different sources, for example NavFac 7.2 - Table 1 (and other sources) uses a friction factor of tan (delta), with no Safety Factor. Coduto, uses mu_allowable = mu/F, where F = 1.5 or 2 and mu = tan (0.7*phi). Have seen suggestions to use (tan(dela))/2, where 2 is the safety factor.
Appreciate your guidance in trying to clarify the friction angle for foundation surface.
RE: Soil-Foundation Friction Angle (Friction Angle for Foundation Surface)
DaveAtkins
With either analysis, an appropriate factor of safety should be used.
Mike Lambert
