NX 9 Drafting Hole Callouts Not Working
I am trying to add a hole callout to a drawing and when I select the radial dimension tool and select hole callout from the dropdown menu it won't let me select the hole on the drawing. I created four holes using the hole tool with it set to counter bore clearance hole, so it should recognize the hole. Any ideas on what's going on? Thanks.
RE: NX 9 Drafting Hole Callouts Not Working
Are the holes part of an pattern? I had this issue couple days ago. I had to select the original holes not that of the pattern.
Some are. I tried selecting the original holes with the same result as before.
Ok great. At least it was a place to start looking. Sorry I could not help you out more.
Install MP9 for NX9.0.3...that will solve it. Also keep in mind that the hole callout is not working for holes placed on a cylindrical face...(ER existing)
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
