Step Translator
Step Translator
Is it possible to use a macro to export multiple step files from a single catpart?
I surface for our simulators and they want each tool(sheet) as a separate step file.
Using a typical draw die, I would have a single upper sheet and two lower sheets.
I would have them named "Upper_Cavity", "Lower_Post" and "Lower_Binder".
Is it possible to click one icon and have it cycle through all the shown sheets and export a step file for each one?
Kevin
Kevin
RE: Step Translator
Probably you will need to open each content of a future step file from CATPart in a separate window and export as step. I believe you can do it with a macro...
Fernando
https://picasaweb.google.com/102257836106335725208 - Romania
https://picasaweb.google.com/103462806772634246699... - EU
