NXOpen Height of the Dimension
Dear Forum,
With NXOpen, how do I get the height of a dimension, note and/or label.
Here's how I am getting the dimension object.
CODE --> vb.net
theUFSession.Obj.CycleObjsInPart(displayPart.Tag, _
                UFConstants.UF_dimension_type, dimnsn)
            If dimnsn = NXOpen.Tag.Null Then
                Continue Do
            End If
            dimObj = CType(NXObjectManager.Get(dimnsn), Dimension)
RE: NXOpen Height of the Dimension
thanks cowski,
How about using the askAnnotationTextBox?
CODE --> vb.net
Dim upper_left() As Double
                    Dim length As Double
                    Dim height As Double
                    theUFSession.Drf.AskAnnotationTextBox(dimObj.Tag, upper_left, length, height)
Depends on exactly what you are after. Using the text box size is good if you need to know how much space the text is taking up on the drawing; also handy if your note is multi-line or uses special text control characters. The lettering preferences are good if you need to know the text height settings as reported in the "settings" dialog box.
www.nxjournaling.com
