Journal to swithc off/on "SAVE JT"
thread561-315251: Save JT Data option in NX7.5.4
Hello Simon,
Is it possible to send me the journals you made in 2012 to switch off/on "SAVE JT" files in NX7.5?
We also work with Teamcenter and I see that it takes al lot of time to save the JT files of large assembly's.
Kurtvdc
RE: Journal to swithc off/on "SAVE JT"
Why don't you just switch off the save JT function?
You can find it under: File, Options, Save options, Save JT Data
Hey,
In our setup (NX-TC) it is no longer possible to toggle off the 'Save JT' option for Designers.
I read that these journals can fix that problem.
Kurtvdc
