TIME INTERVAL BETWEEN DHT AND PWHT
Dear Sirs,
We welded a 15E Pipe material (16 inch - 87mm thickness).
Our procedure will be preheated with 205 deg centigrade then welding and will be
( hydrogen ) bakeout 310 deg Centigrade and perform PAUT, If accepted in PAUT, immediately followed
by PWHT and will perform MT.
Process is B31.1
The joint has been accepted by PAUT, my query is, how long should be acceptable if there is a delay in performing PWHT?
Right now it is almost 1 week that the welded joint is not yet PWHT. What will be your DECISION here?
Need your advise.
Process is B31.1
Need your advise.
RE: TIME INTERVAL BETWEEN DHT AND PWHT
Either case, if there is a delay in PWHT, I would perform a surface NDT (wet fluorescent MT) before PWHT.
