NX Manager Parts referenced by members of the assembly
Hi
NX Manager Help in How to remove (or clean)
Parts referenced by members of the assembly.
When export (to native) and re-import the assembly
I get a list of parts that are not belong to the assembly
but are referenced by members of the assembly.
How I can get rid of them
Thanks in advanced
Thanks in advanced
RE: NX Manager Parts referenced by members of the assembly
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
HPZ420 Intel(R) Xeon(R) CPU E5-1620 0 @ 3.60GHz, 32 Gb Win7 64B
Nvidea Quadro4000 2048MB DDR5
HP Zbook15
Intel(R) Core(TM) i7-4800MQ
CPU @ 2.70 GHz Win7 64b
Nvidia K1100M 2048 MB DDR5
nutace Thank you for your response
Do if I'l wave freeze the assembly will break/remove these references
Thanks in advanced
NX9 / TC10.1.2
HP Zbook15
I mean Assemblies ==> WAVE ==> Associativity Manager ==> Edit Frozen Status
and in the comming dialog I move the assembly to Persistent Frozen Parts Window
My gole is to bypass the error ("not found part" that prevent the re-import to TC)
So I think that if I freez the assembly befor Export to native this will not
records thes references
Is this sound correct ?
Thanks in advanced
Never used it...
What you could do, when importing the assembly back into TC, is set the parts (in import menu) which give you the error, to use the existing part in TC instead.
you do this on The "main" tab - Default Import action - exceptions
NX9 / TC10.1.2
HP Zbook15
