Selection of Boiler for 170 kg/cm2 pressure. 700Tph superheated steam?
For 220 mw steam turbine power plant , what type of boiler do you recommend?
SamPunch
RE: Selection of Boiler for 170 kg/cm2 pressure. 700Tph superheated steam?
"Nobody expects the Spanish Inquisition!"
There should be a study (or series of studies) on the entire generation plant, on the fuel supply and variability, on the ash generation and disposal, on the water supply and purity, expected chemical treatment .... and on and on ..
How is the plant to be operated ? Baseload ? ... Daily cycling ? ... What type of control system is best ????
What are the emissions limitations for the plant ?
All of these matters come into play when selecting an expensive power generation boiler.
Can you answer the question "What type of transmission is best for the SUV that I want ???
MJCronin
Sr. Process Engineer
