Pipe Properties Table proposed by ASME
Hi everyone,
I do remember that ASME has a table proposing values of oil and gas pipeline parameters inducing toughness (conservative values), in case one does not have these parameters in the analyses. Unfortunately I can't find the document . Anyone can help..?
RE: Pipe Properties Table proposed by ASME
What sort of "parameters"?
"ASME" is a very broad term, about as vague as "the industry".
There are many many material specifications - far too many for anyone to produce a table of parameters.
This is like asking the association of motor manufacturers for a set of parameters for a vehicle.... and no more information other than that.
There are lots of people who could help you here, but you're going to need to phrase your question much better and add quite a lot more detailed information about what it is you're doing / trying to do.
