PMI/ 3D Annotations
PMI/ 3D Annotations
PMI/ 3D Annotations
Is there a way to turn on all Information in a Annotation Set?
I have a large model with hundreds of dimensions, notes, and tolerances.
I currently use the search function to select all of each type, but I am looking for faster way.
Possibly a Macro?
Second, I have seen multiple Macros that pull 3D annotation from a CATPart and screenshots them, but has anyone seen a Macro that pulls the annotations from a CATProduct instead?
RE: PMI/ 3D Annotations
I havent found anything about turning on the hidden annotations.
On the second half of my post i was referring to something similar to this thread, only with annotations in the product:
http://www.eng-tips.com/viewthread.cfm?qid=371212
Ill give the first part a shot.
I didnt figure the second part would be easy, just curious if anyone knew of anything that already existed.
I have created this script off of the idea from that thread ferdo.
And it does exactly what i want it to do.
CODE --> CATScript
Language="VBSCRIPT"
Sub CATMain()
Set  ProductDocument1 = CATIA.ActiveDocument
Set Product1 = ProductDocument1. Product
Dim ProductDoc1_As_Document
Set ProductDoc1 = Catia.ActiveDocument
Dim Selection1_As_Selection
Set Selection1 = ProductDoc1.Selection
selection1.Search "CATTPSSearch.CATFTAElement,all"
Set visPropertySet1 = Selection1.visProperties
VisPropertySet1.SetShow 0
Selection1.Clear
Dim specsAndGeomWindow1 As Window
Set specsAndGeomWindow1 = CATIA.ActiveWindow
Dim viewer3D1 As Viewer
Set viewer3D1 = specsAndGeomWindow1.ActiveViewer
Dim viewpoint3D1 As Viewpoint3D
Set viewpoint3D1 = viewer3D1.Viewpoint3D
viewer3D1.Reframe
End Sub
