Connector between surfaces
my question is: Can connector be assigned between two surfaces? Connector with defined failure stress.
These surfaces are flat and they are in contact (no distance between them).
RE: Connector between surfaces
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
You could use nodes of the surfaces or couplings, but not the surfaces itself.
to couple reference point on the surface to the whole surface, and to do the same with the other surface and then to assign connector between these two RP?
Have in mind that there is no distance between this two surface.
