movement to rigid body
I am trying to model a roller in 2d using an analytical rigid and want to apply following Boundary Condition
1. radial displacement
2 rotation about centre outside the rigid body
If i apply both movements at reference point then the centre of rotation keeps changing, which i desire to be as fixed.
Is there a way to apply rotation about a fixed axis and simultaneous radial movement of rigid body.
thanks in advance
RE: movement to rigid body
Place the reference node in the rotation center to control the rotation. Add a connector between this reference node and another one to enforce a radial movement.
Thanks ..
I have tried using connector but not successful can you suggest appropriate connector
