NC FOCUS CHECK
NC FOCUS CHECK
NC FOCUS CHECK
guy, quick question, its been such a long time since I did this and very rare, I forgot how to do this NC Focus Check,
the linear cut from the sheet start at 5.00 and end at 15.00 then I found that the Focal at 12.00 is the best cut, after doing so what's next? how can I input the number so that I can have this focal point?
thank you
RE: NC FOCUS CHECK
It will say default focus, then give a range of adjustments when trying to find. Set that default to 12.
RE: NC FOCUS CHECK
hi, evan1089
thanks for your response but I'm using AMADA LC2415 A3 NT, Fanuc 160i-L series,
RE: NC FOCUS CHECK
If you use 5nc focus function then enter the values 12.00 in the AIVSetting page in the related lens focus (2.5", 3.75". 5", 7.5", 10") you can set them all up if you wish)
If you don't use the 5NC focus function then you set the 12.00 value in the parameter page under focus base position.
cheers
RE: NC FOCUS CHECK
hi, ausman,
thanks, I will check it right away, thanks I really appreciate your expertise,
RE: NC FOCUS CHECK
hi ausman ,
what is the 5NC focus function? I always change my focal point value in the AIVsettings page and didn't know I was using the 5NC focus function
Thank you!
RE: NC FOCUS CHECK
It the ability to use each of the 5 focal different setting in the AIVsetting page.
If the function is on, the control will use 1 of the 5 values depending on which head number you have selected in the cutting data page(top right, 1,2,3,4,5)
If the function is off then the AIV focal point values won't actually do anything.
The only thing that will change the focus would be the focus base position in the parameter page or changing the focus in cutting data.
