NXOpen Getting Feature Assoicated with Dimension
Dear Forum,
Is there a way to get a particular feature attached to a dimension with NXOpen? Say for example, I have a drawing dimension that is associated with a hole feature is there a way through NXOpen to get the instance feature(s) that the extension lines of the dimensions are attached too??
Any ideas?
Any ideas?
RE: NXOpen Getting Feature Assoicated with Dimension
What version of NX?
www.nxjournaling.com
Mike Hyde
www.astonmartin.com
NX8.5 with TC9.1
Moving to NX10 with TC11.2
CODE
Option Strict Off Imports System Imports NXOpen Imports NXOpen.UF Module Module1 Sub Main() Dim theSession As Session = Session.GetSession() Dim theUfSession As UFSession = UFSession.GetUFSession() If IsNothing(theSession.Parts.BaseWork) Then 'active part required Return End If Dim workPart As Part = theSession.Parts.Work Dim lw As ListingWindow = theSession.ListingWindow lw.Open() Const undoMarkName As String = "dimension -> feature(s)" Dim markId1 As Session.UndoMarkId markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName) Dim theDimension As Annotations.Dimension If SelectDimension("Select a drafting dimension", theDimension) = Selection.Response.Cancel Then Return End If lw.WriteLine("number of associativities: " & theDimension.NumberOfAssociativities.ToString) If theDimension.NumberOfAssociativities > 0 Then Dim firstA As Annotations.Associativity = theDimension.GetFirstAssociativity If Not IsNothing(firstA.FirstObject) Then lw.WriteLine("first object: " & firstA.FirstObject.GetType.ToString) If TypeOf (firstA.FirstObject) Is Edge Then Dim edgeFeatureList() As Tag theUfSession.Modl.AskEdgeFeats(firstA.FirstObject.Tag, edgeFeatureList) For Each temp As Tag In edgeFeatureList Dim edgeFeat As Features.Feature = Utilities.NXObjectManager.Get(temp) lw.WriteLine(" feature: " & edgeFeat.GetFeatureName) Next End If Else lw.WriteLine("first object is NOTHING") End If End If If theDimension.NumberOfAssociativities > 1 Then Dim secondA As Annotations.Associativity = theDimension.GetSecondAssociativity If Not IsNothing(secondA.FirstObject) Then lw.WriteLine("second object: " & secondA.FirstObject.GetType.ToString) If TypeOf (secondA.FirstObject) Is Edge Then Dim edgeFeatureList() As Tag theUfSession.Modl.AskEdgeFeats(secondA.FirstObject.Tag, edgeFeatureList) For Each temp As Tag In edgeFeatureList Dim edgeFeat As Features.Feature = Utilities.NXObjectManager.Get(temp) lw.WriteLine(" feature: " & edgeFeat.GetFeatureName) Next End If Else lw.WriteLine("second object is NOTHING") End If End If lw.Close() End Sub Function SelectDimension(ByVal prompt As String, ByRef selDim As Annotations.Dimension) As Selection.Response Dim selObj As TaggedObject = Nothing Dim theUI As UI = UI.GetUI Dim title As String = "Select a drafting dimension" Dim includeFeatures As Boolean = False Dim keepHighlighted As Boolean = False Dim selAction As Selection.SelectionAction = Selection.SelectionAction.ClearAndEnableSpecific Dim cursor As Point3d Dim scope As Selection.SelectionScope = Selection.SelectionScope.WorkPart Dim selectionMask_array(0) As Selection.MaskTriple With selectionMask_array(0) .Type = UFConstants.UF_dimension_type .Subtype = UFConstants.UF_all_subtype End With Dim resp As Selection.Response = theUI.SelectionManager.SelectTaggedObject(prompt, _ title, scope, selAction, _ includeFeatures, keepHighlighted, selectionMask_array, _ selObj, cursor) If resp = Selection.Response.ObjectSelected OrElse resp = Selection.Response.ObjectSelectedByName Then selDim = Utilities.NXObjectManager.Get(selObj.Tag) Return Selection.Response.Ok Else Return Selection.Response.Cancel End If End Function Public Function GetUnloadOption(ByVal dummy As String) As Integer 'Unloads the image immediately after execution within NX GetUnloadOption = NXOpen.Session.LibraryUnloadOption.Immediately End Function End Modulewww.nxjournaling.com
