How to retrieve and use the selected elements from abaqus using pick button in RSG Gui?
Hi
i have created a Gui using RSG Dialog builder in Abaqus.There i used "pick item from viewport" to select elements from abaqus model.now i have loaded the model and Ui plugin. i can pick few elements. now my question is how can i retrieve those selected elements and use it in further script.
Below is the script for pick button:
self.elementDeleteKw = AFXObjectKeyword(self.cmd, 'elementDelete', TRUE, pickedDefault)
RE: How to retrieve and use the selected elements from abaqus using pick button in RSG Gui?
I've created a plugin with geometry picking and was getting a list of faces. So maybe you get a list of element numbers. Just try and use print to get more details on the objects.
