Vessel Material
3
Vessel Material
Vessel Material
Hi Everyone,
May someone know what type of this material (stainless steel or carbon steel) SA105 and SA-516 70 and the maximum and minimum temperature and Pressure for this steel?
Thank you.
Shaga
RE: Vessel Material
Are you asking for someone to Google this for you??
RE: Vessel Material
SA105
SA516 Grade 70
Good luck,
Latexman
To a ChE, the glass is always full - 1/2 air and 1/2 water.
RE: Vessel Material
Antonio .....
There seems to be some major concepts here that you do not understand.
- Pressure Vessels are engineered containers that are built to retain a specific liquid under the limitations of a maximum pressure and maximum temperature. The strength of the vessel depends both on the materials selected and the configuration of the vessel. Agreed-upon rules to design, test and certify a vessel are contained in something called a Pressure Vessel Code.
- Poorly designed pressure vessels have exploded and failed in the past. Many people have been killed
- Pressure Vessels are constructed from approved and tested materials. SA 105 and SA 516 are commonly used carbon steel pressure vessel materials.
- Because a pressure vessel is an engineered structure and therefore the (pressure retaining) strength depends on the materials AND configuration, we cannot answer your question.
Here is a place to start:
https://en.wikipedia.org/wiki/Pressure_vessel
https://www.asme.org/engineering-topics/articles/p...
tell us more about your experience and what you are trying to do ....
MJCronin
Sr. Process Engineer
