What is the state of the art for electronics reliability engineering?
I am not a reliability engineer however am tasked with determining expected lifetime for a simple circuitboard in a manned space application. The supplied specs suggest but do not require HDBK-217. I have read a little about the handbook methods and it seems they are not robust or accurate. The Physics-of-Failure approach seems to be more accurate and cutting edge, but I haven't found any good practical analysis guides other than academic papers and extremely overpriced research software (CalCE requires annual membership fee of $65,000).
What is the next best practical reliability analysis method besides HDBK-217? Any good references or affordable software ya'll could recommend?
Matt
RE: What is the state of the art for electronics reliability engineering?
All the others are similar approaches, except with better databases. Relex is the one we use, which, apparently, was bought out by PTC and is now embedded within Windchill. The reliability data come from SPIDR https://src.alionscience.com/spidr/ and NPRD https://www.quanterion.com/product/publications/no...
So bruteforce-wise, you can grab a indentured parts list and populate with the appropriate values from the database and crank out the failure rate. Note that a space application will probably require some level of redundancy, which will require some other software to plow through hardware design.
TTFN
homework forum: //www.engineering.com/AskForum/aff/32.aspx
FAQ731-376: Eng-Tips.com Forum Policies forum1529: Translation Assistance for Engineers
