Transformer Impedance and voltage drop
I am trying to calculate voltage drop on my transformer...
Primary voltage 16000V ,Secondary voltage 120/240
TX= 100 KVA %z=3.3 1phase
Can anyone help me how to calculate voltage drop on transformer.
The result of my calculation is given me 3.28% voltage drop, However my Supervisor has Voltage drop on Xfmr at 5.26%
RE: Transformer Impedance and voltage drop
xnuke
"Live and act within the limit of your knowledge and keep expanding it to the limit of your life." Ayn Rand, Atlas Shrugged.
Please see FAQ731-376: Eng-Tips.com Forum Policies for tips on how to make the best use of Eng-Tips.
I don't know how he got 5.26%
It looks like he is either adding cable impedance - or he is calculating voltage drop for a much higher load. There is something said about 230 kVA just above the 5.26%
Are you interpreting the task correctly? Or is it your supervisor that hasn't?
Gunnar Englund
www.gke.org
The transformer impedance is comprised of the transformer internal resistance and the transformer inductive reactance.
For voltage drop, use the transformer % regulation at the appropriate power factor. It will be less than the % impedance.
For loads of high power factor the transformer internal resistance predominates.
You must know either the transformer % regulation or the X/R ratio to calculate the voltage drop under normal loads.
The % impedance is only valid for short circuit calculations where the transformer impedance is the only impedance in the circuit.
Bill
"Why not the best?"
Jimmy Carter
So base on this information :
TX= 100 KVA %z=3.3 x/R=3.1
Do you guys get 3.28% voltage drop as well?
This is only voltage drop on Transformer...
Thank you
That's 230.52% of full load current. Is this for calculating voltage dip during motor starting?
If you convert your supervisors figure to 100% loading it comes out as 2.28% voltage drop under full load.
That is probably correct at some power factor.
The voltage drop calculated by % impedance times rated voltage is a directed value. It is predominantly inductive. It can not be subtracted numerically from the rated voltage. It must be considered as a vector.
Bill
"Why not the best?"
Jimmy Carter
There are loads attached to Transformer , But I don't know Which Kva he used! 100kva or 230KVa.
I am getting only 3.6% on transformer . I believe I am using either wrong voltage or Kva..
He has from
TX-------------------Point A Cable-----------------------point B cable.
5.26% --------- 1.26%dropA + 5.26------------- 2% drop on cableB + 5.26
Voltage drop--------=6.52% Total drop on point A---------=7.26%
