Cutter comp ON display symbols in planer mill
In NX9 and previous when using planer mill and cutter comp was turned on you would see a circle at the start of comp and and X at the end of comp. This would visually confirm cutter comp was active. In NX10 I do not see the Circle and the X on the toolpath showing cutter comp being on. Has something changed in NX10 display of cutter comp in planer mill?
Rick D
Win7 64 bit w/NX9.0.3.4 MP9 and NX10.0.3
Vericut 7.4
RE: Cutter comp ON display symbols in planer mill
Actually I have found that when I 1st generate the toolpath the cutcom symbols do not show, however if I re-display the toolpath after generate they show up?
Rick D
Vericut 7.4
Same problem way back in NX7.5 too. Hasn't this been fixed yet?
Proud Member of the Reality-Based Community..
To the Toolmaker, your nice little cartoon drawing of your glass looks cool, but your solid model sucks. Do you want me to fix it, or are you going to take all week to get it back to me so I can get some work done?
