Checking deformation on pressure vessel during hydrotest
Is there any code which dictate to measure the deformation of pressure vessel during the hydrostatic testing and post testing? Testing done against ASME B 31.8 as pressure vessel is associated with pipeline facilities.
Normally we use to measure circumference at start of Hydrotest. Then during the test we check the circumference to confirm how much deformation occurs. At the end of test i.e. after depressurization we take final reading to ensure that there is no permanent deformation. I wish to get some code to support this exercise ? I have gone thru one code "BS 13445-5-2014 Unfired pressure vessels Inspection and testing" which mentioned in 10.2.3.9 " Acceptance criteria -During the proof test the vessel shall show no signs of general plastic yielding. Local deformation which is identified by visual inspection and which is cause for concern shall be referred to the designer for reconciliation against the design specification. During the proof test no leaks are permitted from the pressure envelope"
Can anybody have answer for this.
RE: Checking deformation on pressure vessel during hydrotest
In BS-13121 (this one deals with GRP vessels above ground) there is a max theoric data defined during the testing process
is this vessel in steel or GRP?
Kind regards
Best Regards,
WSU1975
As mentioned in BS 13445 10.2.3.9 "...... Local deformation which is identified by visual inspection......."
No measure is required.
r6155
Pipeline pig traps / scraper traps are NOT PRESSURE VESSELS.
The design code will provide the design pressure and allowable test pressures. Just use that.
I've never ever heard of anyone trying to measure the minute amount of circumferential expansion of a pipe or vessel.
I have seen deformation measured on tubesheet during and after hydro test.
During hydrotest if deformation of barrel happens beyond elastic limit, what is risk associated with the this barrel if it used for operation due to emergency situation. Normally Barrel is used during the pigging.
The DESIGN CODE you are using (in this case ASME B 31.8) will tell you what the test pressure needs to be based on a factor of either Design pressure, MOP, MAOP and is normally limited to 90-100% of SMYS in the material.
There is no code in existence which would require you to yield the material during test and if you've been doing this you're doing it wrong. If you plastically yield an item you are seriously work hardening it and possibly thinning it in places and it won't have the same properties as it did before. A permanent strain of 2-3% is not a big issue, but anything more than that and you've significantly affected the strength of the item.
