Image quality in the exported PDF of drawing
This is on high priority. I have inserted image in the drawing. When PDF is generated and exported, the image quality is very poor on the PDF. What can be done to show it has high quality image?
Image attached for reference.
Nabeena
Nabeena
RE: Image quality in the exported PDF of drawing
Have you tried to change the image resolution setting to High?
You can change it under Settings in the Export PDF Dialog Box.
https://res.cloudinary.com/engineering-com/image/upload/v1456209594/tips/exportPDF_cnvapn.tiff
Thanks for the quick reply. But we use Ctrl+P in Team Centre to generate PDF. When the PDF is opened, the image quality is bad.
I dont know if settings can be done on the drawing before PDF is generated. If you have any idea, please let me know.
Nabeena
So you are generating the PDF through a Workflow in Teamcenter right?
Then it is a little bit more complicated.
I suggest that you contact your Teamcenter Administrator or the person responsible for the workflows.
