Programming Femap/Nastran using Python
This is a bit of a newbie question;
I am in the process of writing an optimization routine in python that needs Nastran output data.
Ideally, it would prompt Nastran to run a number of case(s) and stream the node and element outputs into a text file without all the other stuff that one finds in the f06 file.
I found a link that talks about writing APIs using Python;http://osdir.com/ml/python-windows/2010-12/msg0002...
Installed win32py - No errors.
But for some reason Makepy does not generate a PyFemap.py module.
I am using Python 3.4.2
Any help would be appreciated.
Best BU.
Best BU.
RE: Programming Femap/Nastran using Python
