Crack propagation model
Ive created a 3d cube model in abaqus and incorporated a 3d shell extrusion that is supposed to represent a crack in the cube model. I have assigned loads to the faces of the shelled 'crack' part to simulate tension, as i think that will open the crack. This was done by creating 2 surfaces, one for the top of the shell surface and one for the bottom surface. The said loads were then applied to the two surfaces. When i run the model the following error message comes up and the job is aborting. Does anyone have an idea where im going wrong?
Error in job Job-1: SURFACE DEFINITION ASSEMBLY_SURF-1 NOT FOUND.
Error in job Job-1: SURFACE DEFINITION ASSEMBLY_SURF-2 NOT FOUND.
Error in job Job-1: THE SURFACE ASSEMBLY_SURF-1 HAS NOT BEEN LOCATED
Error in job Job-1: THE SURFACE ASSEMBLY_SURF-2 HAS NOT BEEN LOCATED
Thanks in advance
Thanks in advance
RE: Crack propagation model
Thanks in advance
Thanks in advance
Again thank you for your help!
would you by any chance know how to assign boundary conditions on my said cube if i wanted to simulate the 3 different modes of fracturing?
