Fiber Elongation
Fiber Elongation
A dishend is made using hot forming. The material is SA 516 Gr 70 normalized, thickness is 30 mm and fiber elongation exceeds 5 % . Is pwht and mechanical testing required?
Construction code is ASME SEC VIII-1.
RE: Fiber Elongation
The above applies for normalized or as-formed plates. Read the entire UCS-75.
Also let me know what are the requirements after hot forming and where they are addressed?
Directly after hot forming, you can either air cool the steel (as hot formed condition) or hold the steel at 1650 deg F or higher temperature to ensure complete austenitization, air cool, which would result in a normalization heat treatment or you could quench and temper. You have options.
