Urgent:Install netcdf library for fortran 95 on plato ide
I am using Plato IDE, Silverfrost to run Fortran 95 on windows, I have to run a code which uses netcdf library. How should I do that. When I tried running a code it gave me error 404. saying that cannot find definition for module netcdf. How can I resolve this issue.
RE: Urgent:Install netcdf library for fortran 95 on plato ide
How have you obtain the library for netcdf? Did you build it or was it created by someone else?
If it was created by someone else, did they use Silverfrost to build it or did they use some other version of Fortran?
In the directory that contains the netcdf includes or netcdf libraries, do .mod files exist?
