grooved pipe
grooved pipe
Dear;
I require support for interpreting the following:
- GROOVED ENDS 6MM RUBBER LINED
For example:
- PIPE ERW SCH 40 CS A53-B GROOVED ENDS 6MM RUBBER LINED
Thanks for your support
For example:
RE: grooved pipe
I am not sure what you are doing or looking at, but I will try to help.
Look at this website for examples of "grooved" end fittings and Couplings.
https://www.ferguson.com/category/pipe-fittings/vi...
The Pipe would also have the Grooves on the end of each section. The pipe would first be cut to specific lengths, then (rubber or other) lined, then the grooves would be cut at the ends.
The pipe-to-pipe joint or pipe-to-fitting etc would be joined by a special coupling (see the website). No welding would be allowed, as it would damage the rubber lining.
Sometimes its possible to do all the right things and still get bad results
RE: grooved pipe
RE: grooved pipe
http://static.victaulic.com/assets/uploads/literat...
