very high temperature flexible coupling
Dear fellow engineers,
I need a flexible coupling for my mechanism. The shafts are not very big (2-3 cm in diameter). My main challenge is the ambient temperature which is up to 480 F (250 C).
Do you know any supplier who has such couplings?
the misalignment is not very high. I do not expect it to exceed 1 degree.
RE: very high temperature flexible coupling
More details would be helpful. What are the loads and cycles for the application? A 1 deg angular misalignment can be handled using a metal diaphragm coupling.
You can accomodate both angular and parallel misalignment with a double Heli-call coupling.
Be warned there can be some interesting dynamics if you are using a stepping motor.
Mike Halloran
Pembroke Pines, FL, USA
Have you considered using Oldham couplings? They are quite suitable for bore sizes in the range you specified.
Link
