Save Assembly In Different Directory script help
This script takes the work part (assembly) and creates a new sub-directory under it called NewDirectory, and saves all the parts and assemblies to this one file.
Would anyone be able to modify this so instead of it creating a sub-directory called NewDirectory, it would instead create a new directory on your desktop of the work leaf part and put all the files in there?
CODE --> vb
' This inserts "\NewDirectory" into the filespec of each part,
' after the last folder and just before the part name.
' It saves the piece parts first, then the sub-assemblies,
' and finally the top-level assembly.
' You should then be able to open the assembly from
' the new location using the 'as saved' option if desired
' Only the paths are changed - the filenames remain intact.
' Use cloning if you need to rename the files.
Option Strict Off
Imports System
Imports System.Collections  'This line is required to run this as a Journal
Imports NXOpen
Imports NXOpen.UF
Imports NXOpen.UI
Imports NXOpen.Utilities
Module save_assembly_in_different_directory
    Dim s As Session = Session.GetSession()
    Dim ufs As UFSession = UFSession.GetUFSession()
    Dim lw As ListingWindow = s.ListingWindow
    Sub Main()
        Dim allParts() As Part = s.Parts.ToArray()
        Dim pieceParts As New ArrayList
        Dim assyParts As New ArrayList
        For Each thisPart As Part In allParts
            Dim thisTag As NXOpen.Tag = ufs.Assem.AskRootPartOcc(thisPart.Tag)
            If thisTag = NXOpen.Tag.Null Then
                pieceParts.Add(thisPart)
            Else
                assyParts.Add(thisPart)
            End If
        Next
        lw.Open()
        lw.WriteLine("Piece parts found: " & pieceParts.Count.ToString())
        For inx As Integer = 0 To pieceParts.Count - 1
            Dim aPart As NXOpen.Part = pieceParts(inx)
            lw.WriteLine(inx.ToString() & ".  Original: " & aPart.FullPath())
            Dim newPath As String = _
                       aPart.FullPath.Insert(aPart.FullPath.LastIndexOf("\"), _
                         "\NewDirectory")
            lw.WriteLine("    Saving As: " & newPath)
            Dim pathOnly As String = Microsoft.VisualBasic.Left(newPath, _
                                                  newPath.LastIndexOf("\"))
            If My.Computer.FileSystem.DirectoryExists(pathOnly) = False Then
                My.Computer.FileSystem.CreateDirectory(pathOnly)
            End If
            Dim saveStatus As PartSaveStatus = Nothing
            saveStatus = aPart.SaveAs(newPath)
        Next
        lw.WriteLine("======================================================")
        lw.WriteLine(" ")
        lw.WriteLine("Assembly parts found:" & assyParts.Count.ToString())
        For inx As Integer = 0 To assyParts.Count - 1
            Dim aPart As NXOpen.Part = assyParts(inx)
                "\NewDirectory")
            End If
        Next
    End Sub
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
