Axle wind up: may it damage the driveline?
Hi all,
Why axle wind up is of big corcern for drivelines? May it be damaged by the wind up?
cheers
Pietro
cheers
Pietro
RE: Axle wind up: may it damage the driveline?
https://www.youtube.com/watch?v=k2eXvhdAviM
An entire industry provides products intended to combat leaf spring wind up.
This is an early one.
http://tractionmaster.com/
The issue is "wheel hop". The axle winds up, the geometry of the suspension pulls the wheel upward, the wheel loses traction and spins, the axle unwinds and that tramps the wheel downward, the tire regains grip but that winds up the axle. This sets up a big oscillation, and if the amplitude of that oscillation gets big enough, you can certainly start breaking things. You can see the axle hopping and tramping up and down together with the leaf springs winding up and unloading in that video.
All sorts of add-ons have been invented to combat this, usually called "traction bars" or "slapper bars" or some such thing.
Other types of rear suspensions which don't have as much compliance in the axle-twisting direction are the proper way to fix this.
Cheers
Greg Locock
The parts cost ~$300, way back when that was a lot of money.
Mike Halloran
Pembroke Pines, FL, USA
@Greg,
if the statement above is true, how torsional oscillation may be generated?
thanks
Driving around in a 4x4 vehicle with the front and rear axles locked (no center diff and no slippage allowed) will indeed cause the rear wheels to push and the front wheels to drag when going around a corner because the front wheels travel a longer path than the rear ones do. Something has to give. Hopefully, one of the tires starts slipping. If the front-to-rear interconnection has compliance in it, it will store up some energy in the form of winding up or loading up whatever has compliance until such time as either a tire loses grip ... or something breaks because you are doing this on a very grippy surface that doesn't allow tire slippage to release the strain before something breaks.
On a low speed vehicle like that, axle tramping and oscillations as shown on the drag-race car shouldn't be of concern.
I'd expect a very strong mode consisting of the mass of the tractor driving back and forth on the stiffness between the front and rear contact patches.
Cheers
Greg Locock
Norm
@BrianPetersen: I'm sorry for not being clear enough, I knew only that wind up and from your answers I realized there are many other types of wind-ups
