difference between end mill and drill bit
Can anyone please explain What is the difference between end mill and drill bit?
RE: difference between end mill and drill bit
Google​ ​is your friend.
Also,
You can do a search in McMaster-Carr
End Mill: Used for machining shapes/features from raw stock. Can also be used to make holes.
There are various types of end mills.
Drill bit: Drilling holes.
Chris, CSWP
SolidWorks '16
ctophers home
SolidWorks Legion
In the most basic sense--
drill bits cut round holes with sharp tips in the axial direction.
Mill bits have sharp sides and are for cutting in the direction perpendicular to the axis.
Drill bits break when you push them sideways, end mills cut.
A conventional end mill is not capable of cutting at its end face center, at the axis of rotation. The mill end face has cutting edges with a negative rake that are designed to cut at the outer corners. When plunging an end mill into a surface it must use a helical path. The sides of the end mill have helical reliefs that are designed to move the machined material away from the cutting location as efficiently as possible.
Conventional twist drills are capable of cutting at their end face. They have overlapping end face cutting edges with a positive rake. They also have helical side reliefs that are designed to move the machined material away from the cutting location as efficiently as possible. Twist drills are not designed to remove material at their side edges.
With modern CNC milling machines, it is often more efficient to use an end mill for making larger diameter, close tolerance, shallow depth holes than it is to use twist drills. Twist drills are mostly used for making deep, small diameter holes. But this normally requires "pecking" the twist drill in and out of the hole to clear chips and keep the drill bit tip from wandering.
Reamers are designed to remove a small amount of material from the sides of an existing hole, to improve the hole's precision and smoothness. Reamers cut a bit on their leading edges and also on their sides.
An example :end mill cuts slots and drills makes holes.
Raviprakash369:
Come, come now..., this is supposed to be a forum for tech and engineering professionals. Isn’t your question something akin to asking what’s the difference btwn. snow shoes and ballet slippers? Maybe the difference btwn. a feather duster and a bull dozer? I hope to hell you are not designing any airplanes.
