Cutting 7Ga mild steel with nitrogen
I was asked to find some solutions for cutting 7ga mild steel with nitrogen. We have no problems with 10 ga or less we do it all the time and the feed rate is still fast. I was given some things to try from Amada but had no luck and the feed rate was so slow. So I want to find out what others are doing when the 7ga parts they cut have to be laser scale free because buffing by hand stinks.
RE: Cutting 7Ga mild steel with nitrogen
