WPS FOR DIFFERENT P-NO./G-NO.
HELLO,
WE HAVE A PROBLEM IN WELDING OF MATERIAL WITH SAME P-NO. BUT
DIFFERENT GROUP NOS.
AS WE FOLLWD ASME SECTION IX WE FOUND IN QW403.5 THAT IF THERE IS NOT ANY CHANGE IN ESSENTIAL VARIABLES EXEPT IN GROUP NO. THEN WE CAN QUALIFY PROCEDURE FOR WELDING OF THE SAME MATERIAL WITH THE SAME P-NO. AND GROUP NO. AND THEN IT QUALIFIES WELDING OF TWO TYPE OF MATERIALS WITH THE SAME P-NO. BUT DIFFERENT GROUP NOS.
THIS PROBLEM IS SPECIALLY IN WELDING OF PIPES TO FLANGE AND FITTING WHICH HAVE DIFFERENT GROUP NOS. AND EMPHESISE THAT ALL ESSENTIAL VARIABLES (ELECTROD,FILLER,...) ARE THE SAME AND DIFFERENCE IS JUST IN GROUP NOS.
RE: WPS FOR DIFFERENT P-NO./G-NO.
If it does not, then since Group # is a supplementary essential variable in ASME Sectin IX you can basically ignore it for the purposes of weld procedure qualification. One P No. welded to the Same P No. would qualify all of the metals of that P No. regardless of which group they are in.
If the material does have impact property requirements, then the group number becomes an essential variable. You can only weld the specific group numbers you qualified.
Is your "problem" a real "physical" problem or a code/paper one? If an actual welding problem, what is it-eg. cracking, etc. Many more specifics would be required.
Thanks and regards
Sayee Prasad R
Ph: 0097143968906
Mob: 00971507682668
