Rayleigh damping in Abaqus
Dear all friends,
Is there any one who know the unit of w (the natural frequency) and fraction of critical damping in the equations of the Rayleigh damping?
The equations are the followings:
aR=2*w1*w2*(the fraction of critical damping)/(w1+w2)
BR=2*(the fraction of critical damping)/(w1+w2)
What is the unit of w? Rad/sec or Hz?
Does the fraction of critical damping substitute in term of percent(%)? (e.g, 0.05 or 5)
I look to hear a positive response from you.
Thank you so much.
RE: Rayleigh damping in Abaqus
w in rads/sec, fraction of critical damping is unitles, e.g. 0.05 for 5% damping. You can easily work out expressions for Rayleigh coefficients by using definitions of the critical damping and the Rayleigh damping.
Dear bkal,
Thank you so much for your response. As a consequence, I should substitute those parameters in the above equations in term of units which you pointed out them, do not I?
Would you please introduce me a text book or a resource that refers to that units which you told me, because I want to refer my information to them.
Thank you for your response
Best regards.
This is all based on two simple basic dynamics equations which you can find in any textbook:
1. natural frequency of the system,
2. critical damping of a system with viscous damping,
Once you introduce these into a formula for Rayleigh damping, you will end up with a system of two equations with two unknowns (ALPHA and BETA), solution of which gives equations you have quoted.
Dear bkal,
