Help on NX Expression
Hello Good day,
I have a schenario where I have created a Feature group in NX,
while adding the Feature group into a new part is it possible to retain the same Expressions which is existing in the Feature Group
Could someone please address this
Thanks.
Thanks.
RE: Help on NX Expression
Are you seeing something different than this?
Taylor Anderson
NX Product Manager, Knowledge Reuse and NX Design
Product Engineering Software
Siemens Product Lifecycle Management Software Inc.
(Phoenix, Arizona)
but is it possible that it copies the expressions in the Feature group rather than duplicating the expressions.
For an Expample a Expression of a hole is fed as Drill Dia = xxx in the Feature Group.
when I use the Feature group in a part it should carry the same expression instead of the giving a new expression ( Pxxx)
Thank you.
