LC 2415 A3 NT need help in IF board
[b]AMADA 2415 AIII NT C3000D
IF Board (A16B-2100-0141)[/b]
guys, I need your expertise in this one,
[b]A/D converter alarm[/b], I replace and check all 24V including the IC, and the alarm is still there, I replace the whole IF board, and still the alarm is still there.
I've even check the power supply PCB and the Input board and there is no problem with it. the laser fanuc control panel is not working, only the alphanumeric soft key beside the screen is responding, and beside the A/D Converter alarm there is also code [b]2101 circuit protector trip[/b] alarm, I try to check and figure it out, but there is no trip in all my breakers, the alarm wont move. I've been fixing this machine by my self, I have no contact with fanuc or amada.
did I miss something? please I need help guys. thanks
RE: LC 2415 A3 NT need help in IF board
P.s. could be QF11
thank you very much for your time, I will check it now and come back, I really appreciate it. thanks a lot.
by the way thank you again for your expertise
The long and short of it is I think there is something wrong with the way you connected the interface board.
I worked on a Cincinnati that had a Fanuc laser on it. The laser would go through normal start up, but would sit at sequence 20 till you hit the H/V ready button then it would start the rest of the way... It sounds like your machine, the interface board, is looking for this signal. Amada machines are not set up that way.
I don't think it's got anything to do with an emergency stop condition. If your laser was running right, when ever you hit the e-stop, it drops out the high voltage and sits at sequence 20.
thanks for giving your time on this, i connected the interface correctly, and beside there is a label on the interface that can instruct you easily, but to think of it there is a little difference in the new interface and the old one, i attach some picture, it might help some how, i hope?
as you can see the image, the new IF Board has a jumper between DIL2 & DIL1, and at the Link 1 the Jumper was on the Left side, for the old IF Board, the Link 1 was on the right and no jumper between the DIL1 & DIL2, so I followed the old setting because the laser is working before, do you think this has something to do with it?
so this is a picture of my IF board but I mark it with red,
the circle is where is my connection or my wires connected, the x mark is not connected, can I ask what is the DIL1 & DIL2 is for? and at the link 1 does do? just curious? thanks for being patience.
i've also notice that but i have no connection for ESP 1 & 2, and ON & OFF i only have the blue cable and OF11 & 12
I don't know what DIL 1 and 2 are for yet, but try moving the jumper to the right side if you are using the fiber optic cable COP1.
im sorry, have more patience on me, i really appreciate your help,
i hope thats will solve the problem, thank you for you patience, i will update you as soon i have the result sir,
thank you very much, you were right, as always, it already pass sequence 20, and tomorrow i will start aging,
