Simulating the effect of rainfall in the soil - GeoStudio
Hello guys!
Does anybody know if it is possible to include details about the rainfall (intensity and duration) to analyze its effects on the soil stability? I'm currently using GeoStudio 2007.
Thanks!
Renata.
Thanks!
Renata.
RE: Simulating the effect of rainfall in the soil - GeoStudio
In my opinion, strength of clay material depends also to water content. If the moisture of clay goes up, the strength parameters will be decreased. But definiton of this behavior is not seems to be possible. We can assume some layers to be affected by rainfall and can decrase the strenght parameters. But the main issue seems to be if there is any potential failure surface, we can not guess it. Water can be flow on some sand layers in material, can decrease the strenght parameters of clay significantly. I think only God can do what you saying :)
Alternative is to use a worst case scenario or credible worst case assuming some layers become saturated after rainfall and the subsequent effects on phi-c and Cu, if existing failure surfaces exist then on such surfaces softened values should be applied (which ones is also a critical and sometimes tricky choice).
www.mccoy.it
