Bystronic 4020 3kw cooling liuqid
We are using demineralized water for cooling. The system is working fine, but we have a problem during the winter season because we don't have good heating in the room. The temperature may fall till -15C. Usually the radiator units crack. Is it possible to use water-glycol solution to protect the system from freezing?
RE: Bystronic 4020 3kw cooling liuqid
