SubModeling in Abaqus
Hi all,
I have the input ODB file with customized step created in step module.Now ,should I select static,general step or create same customized step once again to get the same result for the sub model?
RE: SubModeling in Abaqus
There is a GLOBAL MODEL and a SUBMODEL. I suppose that you are asking if you can use a different step on the SUBMODEL. It is a posibility if you have the specific purpose. You can make a dynamic step in your GLOBAL MODEL and for some specific region make a SUBMODEL with a static step. Is up to you verify that the SUBMODELING assumtions are correct.
If you want to reproduce the same conditions you must use identical steps, loads, BC,etc in both GLOBAL MODEL and SUBMODEL.
You can read about this in the manual.
