Issue with Configure Fastener Assembly
I am trying to config a fastener assembly that has Hex Socket Button Head screw. When I use the Reuse library in the resource bar. I can easily find the Hex Socket Button Head screw in ANSI Metric standard. Here is an snapshot:
However, when I try to config a new fastener assembly, it only lists Hex Socket Head Cap Screw and Spline Socket Head Cap Screw and there is no screw type of Hex Socket Button Head screw in ANSI Metric. Here is an snapshot:
Does anyone know what may be the issue and how I can config a fastener assembly with Hex Socket Button Head screw?
