Wire Bending on Roller.
Im trying to simulate a wire bending on a roller. Im doing this with axis-symmetry plane analysis. However my explicit analysis end up with "NODE SET ASSEMBLY__PICKEDSET19 HAS NOT BEEN DEFINED". I have been modifying the BC of part 2-1 which i assume the node set is located. Im gladly to hear any opinion to improve my simulation.
Hereby i attached the inp. file for your review.
Thanks.peace
RE: Wire Bending on Roller.
When you create a BC for a particular node region, you select it while defining the BC. That node set is saved by abaqus as *_pickedset. When you make any change at all to the mesh of the related part, the *_pickedset is invalid. You will have to check the boundary condition and redefine the node set.
Hi @tkks2040,
Thanks for your reply. I have tried to remove all the BC and recreate them again but the error still occurs. Here the new inp. after remaking all the BC again. Does "redefine the node set" means re-selecting the node in BC? cause thats what I do. Could I have done it wrongly?
ponder
Yes. Redefining the node set means reselecting the nodes for the BC. Instead of picking them during BC definition, I'd suggest creating them in the part module and then accessing them during the BC. That'd help with clarity.
Hey @tkks2040
Thanks a lot to your explanations. Now I able to figure it out. Just remake New Node Set in part module and set it in BC again.
Hope this help others too.
Cheers!2thumbsup
