PATRAN - referring a vector to other than the global one
thread824-281221: How do I specify bar orientation with a vector other than Coord 0?
I was guessing too if it were possible, for example, to orientate a bar section referring to a coordinate
system other than the global one, i.e that in Patran is called Coord 0 .
After looking for how to do I finally found it is possible with the following syntax, if for example
one wish to use a vector referring to a new system, let's say, called Coord 1:
<x y z> Coord 1
That's all! Use the same syntax also in the node offset and it works great. I have written this here if someone else needs it
(I lost a lot of time to find it).
