Vacuum Pump Basics
Vacuum Pump Basics
I need to design vacuum pump for solvent recovery. I am a beginner in this field.
How does one approach design vacuum pumps? Can someone explain the basic details of vacuum operations with reference to certain numerical calculations?
please explain the significance of terms like :
1. mAx Vacuum rating
2. Inlet temp
3. outlet temp
4. bleeding rate
5. pump system temperature
Any links to docs explaining basic calculations and operations will be really helpful.
RE: Vacuum Pump Basics
Why? Just buy one from someone who's been building them for a long time.
Starting at such a basic level needs a lot lot lot more than you're going to get on an internet forum....
Sorry
or this
https://www.pfeiffer-vacuum.com/en/know-how/vacuum...
or this
https://www.festo.com/net/SupportPortal/Files/2868...
Google is your friend, learn to cuddle up to him or her or it and read, then come back with some more specific questions.
I agree that I need to be specific but the reason I asked it here is that Google is a friend but it gives so many options, here with you all experts I can get specific and precise advice.
Thanks for the link anyways.
One thing you learn about vacuum is that the time to create whatever low pressure you want is a logarithmic type curve and to get very low vacuum conditions can take weeks.
Gabriel Castaneda, P.E.
http://www.gabcheminc.com
