Applying concentrated load
Hi
I am a 3rd yr civil student and am running an experiment on how cracks behave in Abaqus. But i am stuck on the first part of my experiment, I am simulating a soil particle in the shape of a cube. I created a standard 3D cube shape and i want to apply a concentrated/point load to the top face of the cube at the middle. How can i make a node in the middle of this face active so that it will allow me to have a load contact the cube at that point?
Also is it possible to apply a concentrated load onto 1 single node on the top surface of the cube, or do i have to create a small surface for where the load will be applied to?
At the moment i have created my cube part, then in the Interaction module i created a datum point at the centre of the top surface (made that a reference point 1) then i created a datum plane that is perpendicular to the top surface and created another datum point (made that reference point 2) at the centre of the new plane. I then constraint the two points by selecting coupling, picking RP2, then node region, and selected RP1. In the next box i selected kinematic option (didnt change anything else in that menu). Then i applied a load through RP2. When i run the job it keeps aborting.
I dont understand how to get around this and would appreciate any help possible
Thanks in advance
S
Thanks in advance
S
RE: Applying concentrated load
Are you new to this forum? If so, please read these FAQs:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
