emergency lifter design
I'm about to design a very simple emergency lifter its aim is to lift the workman while the man above the truck,it is required to be simply contains column and cantilever beam the column height=5m and attached cantilever beam length=4m
Does anyone have suggestions how the system can be simple and of course stable because it is required to be transferable?
Also how can I assume the impact factor over the cantilever beam if the man fall?
please see the pic
please see the pic
RE: emergency lifter design
One problem is that the person should wear a harness, and that seldom happens in reality.
Jason McKee
proud R&D Manager of
Cross Section Analysis & Design
Software for the structural design of cross sections
Moment Curvature Analysis
Reifnorcement Design etc.
